Cancelled
Anyone up for a run to Cleghorn or 2N17X or both this weekend?
This is a shot of a TJ trying to make it up the hard part of 2N17X. This rig had to be winched up. There is a bypass for this part. If you aren't familiar with 2N17X it runs from the spillway at Silverwood lake along the ridge. Great views. It's a short run, can be done in a couple hours. Not a lot of rocks, but alot of steep climbs and dirt moguls with some off camber spots. At the top there is an area with some rocks to play on. If that's your thing. The spot in the picture here is where several rigs have rolled over recently. But as I said there is a bypass, so there is no need to risk anything. Cleghorn is close by as well. The terain for Cleghorn is the same as mentioned above, just on the other side of Silverwood lake.
