2LTE Glow Plug resistor
Edmonton, AB
Hello,
The wire from the # 2 glow relay to resistor is shot. I want to bypass the factory wiring and resistor. This resistor is used in the Super Glow system to drop the voltage to 6ish Volts. It attached to the lower side of the intake manifold. here's a pic
http://pg.photos.yahoo.com/ph/rummat_fast/detail?.dir=d3e9scd&.dnm=6aafscd.jpg&.src=ph
Can someone tell me that is the ohm rating for this resistor. I would want to wire the resistor seperately from the relay to the glow bus.
how many ohms is this resistor. any other specs would be appreciated.
Although i have the EPC, i cannot find a part number for it .
thanks.
Ali.
hi guys,
I took it out and the resistance seemed to be 34~35 ohms and according to the markings on it, it drops 3.6 volts.
Ali.
