2JZ anyone?
I had a 95 Supra TT, those engines are beasts!!! bulletproof! i couldnt find any 2JZ Turbo engine swapped, however i believe i seen a 2JZ NA motor swapped and turboed, but i dont recall.
Anyone seen one? 6 speed tranny from TT might not work because its so huge, but would a TT Auto work or stock tranny possible with the TT 2JZ?
would love to hear some ideas, i keep looking for a 95-97 80 but most of them have 180-250k miles so im thinking i might as well buy a cheaper one and do an engine swap of some sort to improve MPG and maybe power.
Not a good idea. A typical 80 weighs over 5000 lbs, and needs lots of low-end torque to get going. The 2JZ, while a truly excellent motor, doesn't make the needed power in the low end.
even the TT? cuz the supra was one heavy pig, and stock 0-60 in 5 seconds is no funny, well i never drove or even checked an 80 out in person, im still looking for one around here to go take a look at
Agreed. But like I said, if you're going to do an engine swap you'll need a lot of low-end torque, something the 2JZ doesn't offer. Even the TT. The 1FZ (4.5L, 93-97) makes most of it's power below 2000 RPM, and the 3FE (4.0L, 91-92) makes max torque at a mere 3000 RPM.
V8's are popular for the swap people, there's even a Corvette motor in one. Though he had to change the valve body on the tranny so it could shift higher.
Also (I really don't mean to be rude...), if you're going to swap motors, don't do it for MPG gains, there isn't much to gain.
Again, these trucks are HEAVY.
I guess it would be pointless to explain torque curves to the OP.
#'s don't mean s***, smart guy. It's where those #'s are......
Here's a 500+ H.P car, that put in to a LandCruiser, it wouldn't...couldn't, even get to the speed limit
YouTube - Ferrari F1 car startup and light revving
Still think #'s are important? :hillbilly:
#'s don't mean ****, smart guy. It's where those #'s are......
Finally, a Hilux post that makes sense. :flipoff2:
Try to be nicer, though.
