My #4 wrist pin came loose and scored the crap outa the cylinder. The piston looks fine but the top ring is of course broken as you might expect. The issue is the pin. Should it be so loose in the piston as to easily slide back and forth when the wrist pin bolt is loose? I think the bolt was not properly torqued by whom ever put it together the last time. I'm wondering if maybe the wrist pin hole may be to loose and cause problems when put back up. I can't feel any movement or play when wiggling the rod.
What say you experts?
Jim
Jim
