2f wiring into a new 3fe engine install
Putnam,CT
I have installed a new rebuilt 3FE into my 1976 FJ40 . Purchased from Cruiser Parts . came with a wiring harness and ECU that is an almost plug and play set up but we cannot figure out the wiring for the Fuel pump and igniter coil . Has anyone simplified the colored wires and their placement
Ignitor wiring comes from a green four pin and is integrated into the 3fe harness. Should be self explanatory if you have the ignitor. Follow the air flow flap wiring, I think it was integrated into that portion of the harness. The fuel pump I'd have to dig out a harness schematic . I can dig out a schematic and take a pic later
great . I believe its the ISC1 thru 4 . I will find it and send pics also later on
Appreciate the help
They included the Coil-ignitor and it is set with the green 4 wire plug. We believe it might not be any good . Need to test it
We are going also try and trace all the colored wires back to the ecm and see if they are all correct
If you look at my thread in my sign line it might help. I'm traveling till Tues but the schematic says red with green as hot to pump and white with black as ground. Also double check that the neutral safety switch was bypassed and the two in that pic are connected. I can send you an ignitor and coil to test but need it back.
Also the efi circuit open relay needs to be checked.
Thanks. I will check the coil. and the relays
We are red with green to the fuel pump.
