2F Smoking
Montgomery Co. TEXAS
Website
missionsonwheels.org
The other day I noticed my '78 2F blowing puffs of smoke everytime I shift gears. I assume this would be valve stem seals? SOR wants $4 a piece for them and my local parts stores only want to know if my 40 is air conditioned then tell me they don't find a listing. Does anyone have a better source for these parts? Is this the correct diagnosis of smoking issue? What will be involved in the repair. All help appriciated. :beer:
Thanks,
Mike
Mike, I know nothing about Toyota smog stuff or if you have desmogged yours.If it started all of a sudden it could be PCV valve? When you back off to shift vacuum goes way up. I had an MG that would do that between gears and really bad when downshifting. Turned out to be a $15 "Gulp valve".
Smoking on startup then quitting can also be valve guides.
GL
Ed
This is my traditional understanding of bad valve guides. When the motor sits for a while, oil seeps down into the cylinder past the valves. I don't think you'd get enough oil while it's running to make a visible puff of smoke.
Bad rings would probably be evidenced more often than just while shifting - especially when hot.
The PCV valve idea seems to make sense.
Good luck,
Eric
Mike, sometimes you can soak them in parts cleaner or lacquer thinner and free up the ball or whatever rattles. You can disconnect the hose to the carb base at the PCV valve and plug it, then drive around and see if you solved the problem.
GL
Ed
I found this on the web. Maybe it will help.
Exhaust Colors: A small puff of white smoke on start up is considered to be normal on a modern emissions controlled vehicle. If the smoke is occurring at other times that start up, something is wrong.
Black Smoke – Rich condition. Usually visible during acceleration but can occur at any time. Excessive fuel, could be caused by a zillion things; MAF, TPS, leaky injector, bad O2 sensor, etc…
Blue smoke during acceleration – Oil leakage past rings. Confirm by measuring compression, squirting oil in spark plug hole and re-measuring. Change should be less than 10%.
Blue smoke during deceleration or on start up – Bad valve stem seals (valve guides).
White smoke acceleration – Coolant leak into cylinders. Possible causes are leaking head gasket, intake manifold or TB coolant leak. On the LT1, the intake manifold does not carry coolant, so you can rule this out. Frothy coolant? Head gasket, for sure!
White smoke during idle or deceleration – leaking intake manifold gasket. Not likely on LT1, see #4. Possibly – extreme case of blown head gasket.
Smoke under deceleration means the valve guide seals are letting some oil go past them.
Good luck!
GL
Ed
Spray the PCV valve out with carb or brake cleaner and shake it intil it rattles. Let it dry and re-install. Or you can go get one for a couple of bucks.
Later,
