2F Rebuild Kit
does look like a great deal. much cheaper than some other overhaul kits I've seen like sor
closer look, maybe the pic is wrong, this kit is for a 4 cylinder. but it does say 2F so...
Call Gary Kardum at Mudrak's and have him get all your parts. Or have a machine shop get your pistons, rings, crank shaft bearings. The balance of the parts you can get from Toyota. If you are a TLCA member you get a discount from some dealers or get a hold of CDan her on mud (check the vendor section). Make sure you use a Toyota Engine Gasket Set.
