2F Plus Misc Other Parts for Sale
SC
Website
www.southeastoverland.com
PRICES REDUCED - SHIPPING EXTRA
If they don't sell at this price I'll take them to GSMTR for the swap meet
I have a bunch of 2F parts for sale from a 1976 FJ55 and a 1983 FJ60 - plus some other miscellaneous stuff I've amassed over the past few years that I want to get out of the way for a new project. All parts are OEM unless otherwise noted. I will confirm before you pay.
All prices do not include shipping or any packing materials I have to buy. I have a bunch of newspaper and wrapping material in the garage but might run low pretty quick on boxes - we are only talking a few bucks here. I live in zip 29690 but will be shipping from a nearby FedEx location that has pretty reasonable shipping prices. I've used them to ship recently to Florida and I thought it was pretty cheap. Don't be shy - make an offer if you want! If you want more than one part I'll knock some off. :beer:
I would like to shoot everyone a pic of what they want before you buy to make sure we are clear on what is being purchased - part and condition.
I could arrange delivery of some parts. I will be in GSMTR (Murphy NC) June 15-20, in Columbia SC every month or so and in Atlanta one or two times over the next few months.
1983 FJ60 2F Parts
These parts came off of a motor I bought as a rebuild core. Anything listed below was not driven in a truck but the PO was able to crank the motor outside of the 60.
Charcoal canister mount $5
Fan clutch $25
Fan $5
Coolant overflow bottle $5
Engine mounts - brand new paint $15 each
Alternator - shape unknown - not OEM - consider a core $10
Oil pump $25
PS pump reservoir $10
AC compressor? plus additional AC parts - what are these worth?
Fan shroud $10
Valve cover - brand new paint - nice $40
1976 FJ55 2F Parts
Everything below came off of my Pig and worked fine. The engine went south b/c of a bad crank and harmonic balancer. There were no other issues that I know of.
4 main bearing caps $10
Fuel pump $20
Oil pan $40
Side cover - non dented $5
Clutch inspection cover $10
Timing gear cover $10
Oil pump $20
[STRIKE]Exhaust manifold - frozen flapper $30 SOLD[/STRIKE]
[STRIKE]Valve train $25 SOLD[/STRIKE]
[STRIKE]Head - desmogged - bottom of valve seats 'peened' - you want pics - has good parts $15 (shipping would suck) SOLD[/STRIKE]
Push rods - 12 total, 2 are smaller diameter on the top $10
Speedo housing $20
Water pump - low miles $50
Oil filter mount $5
[STRIKE]Thermostat housing - 1 broken bolt $15 SOLD[/STRIKE]
Starter - non gear reduction $10
[STRIKE]Bell housing $15 SOLD[/STRIKE]
12 lifters $10
6 pistons - engine rebuilder said these were good $50
Misc Parts
4 drum shoes - good shape $20 for all
4 drum brake cylinders - 1 leaked when removed $30 all
[STRIKE]2 clutch forks $5 each - SOLD[/STRIKE]
[STRIKE]Exhaust manifold - unknown year - weak flapper $30 SOLD[/STRIKE]
2 drum rotors $10 for the pair
[STRIKE]1 Flywheel $20 SOLD[/STRIKE]
Clutch and plate - 1 set $25
Mini truck PS pump (small dent in pulley) $20
Misc smog parts I need to dig through
Thanks! :cheers:
Steve
Do you have the block for the 2f still if so let me know how much for the block and all the parts for it. I am looking at building a 2fe with it.
Thanks
Dave
Steve
Thanks
Dave
I don't have the block for the 76 but I do have another 76 pretty much complete that you can have. It needs a rebuild. I got it from another UC member for 3 nice 6-packs so you can have it for the same we can arrange delivery/pick up.
We might have talked about this earlier - it does NOT have the PS mount on the block but you can get a mount from IPOR or several other vendors.
price on the ENTIRE ac system?
Below is a pic of the AC parts I have.
Do you have any bolts available?
If so, I am looking for Bellhousing bolts, flywheel bolts and pressure plate bolts. Also, motor mount bolts if you have them...
Thanks,
Jonny
i'll take the 2 clutch forks.
Yes sir - please PM me your shipping address.
Thanks,
Jonny
I've got a bunch of bolts. I didn't list them though. I'll pick through them tonight for ya.
:cheers:
Awesome - thank you very much. Also, if you have any other bolts - namely ones that hold accessories and brackets onto the motor I would be interested in those also... Thanks again,
Jonny
I've got a bucket full of bolts. I'll lay out the bolts and take a pic tonight. Without inventorying everything I would guess I have just about enough to put together a 76 2F.
I don't have a clue what the bolts look like - so if they were in your picture I couldn't pick them out... I'm learning as I go!
How much would you want for your bucket of bolts shipped? I will return everything I don't use ;)
Thanks,
Jonny
I'm always learning!
If you just need the bellhousing, flywheel and pressure plate bolts I should be able to pick those out. I have a ton of bolt reference pics if you want for me to email those to you. These pics show bolts labeled as to where the go laying beside a ruler for length. PM me an email and I'll send them to you.
I'd prefer not to sell all my bolts as they are all my bolts! :D My rebuilt 2F is not totally in yet so I could end up a creek without a paddle but I would be happy to sell you whatever ones you need.
Thanks,
Jonny
Check your PM :cheers:
Jonny
Here are some pics of the parts. I also added a 1983 FJ60 charcoal canister mount for $5.
2F valve cover - freshly painted
1983 FJ60 AC Compressor - whats this worth?
Mini truck PS pump - was on my 1976 Pig but I replaced it with a Sag pump just b/c of the need for a different adapter bracket and it was easier to get a Sag bracket than a Mini bracket. Worked fine.
Note very slight dent in pulley.
Smog parts - let me know what you want.
Example of brake shoes. This is the best of 4 - all have good life left but the other three have the blue paint peeling off.
Thermostat housing - 1 bolt broken off - can see in pic.
Oil filter mount - I'll clean it up some before I ship.
Alt - aftermarket - consider a core - it supposedly worked when pulled but that came from a PO
1983 FJ60 Coolant overflow canister?
1983 FJ60 fan blades - good shape
Brake cylinders from a 1976 FJ55 - have 4, 1 leaked
Clutches - 1 OEM, 1 might be aftermarket
I'll take some more pictures soon.
:cheers:
