2F overhaul gasket kit-Fel Pro (NEW)
Status
Not open for further replies.
New in the box Fel Pro overhaul gasket kit. This has been sitting in the garage for some time, unopened. It is not bent and all the pieces are there for a complete overhaul. The bi-metal exhaust manifold gasket has some rusty like dust on it...but I think that would wipe off at install. The Fel-Pro part number is 21219B and is tailored for a 75-80 2F motor. Save yourself $50 in gaskets....and buy this for $60 plus shipping.
Send me a PM to work it out. Paypal or money orders seem to work fine.
This kit has EVERY gasket needed to overhaul a 2F?
Thanks
Thanks
Yes...it appears so. Without opening the plastic and spoiling the kit, here is what I see I see in the plastic....Cylinder Head Gasket, Manifold Gasket, Valve Cover Gasket, Valve Cover Top Seals, Valve Stem Seals, Thermostat Gasket, Top Thermostat Gasket, Water Outlet Gasket, Exhaust O-ring (donut) Gasket, Timing Plate Gasket, Timing Cover Gasket, Timing Cover Oil Seal, Fuel Pump Gasket, Water Pump Gasket, Oil Pan Gasket, Rear Engine Main Seal
For comparison prices check out the non-fel pro stuff sold by manafre or ccot....this is a good deal even if it misses some of the small items like an Oil Pressure Regulator Gasket, Oil Filter Flange Gasket, Drain Plug Seal, or Side Cover Gasket.
See http://coolfj40.stores.yahoo.net/ovkit2fen.html
This is Fel-Pro....good stuff.
Status
