2F Head Bolt Stretch Spec?
The head bolts on toyota I-6's are pretty masive and with the weak compression these engines had bolt streach should not be an issue. As far as a factory spec i have never seen it. If bolt look goood visually and you are not going to run over 10:1 compression i wouldn't worry.
As long as there is not any massive corrosion/pitting on the shank I would use them. Make sure that the threaded holes in the block are clean and free of dirt, cleaning solvent, etc. Leaving fluid in the boltholes can cause a block to crack when torque is applied to the head bolts during installation. Toyota suggests using a light coating of oil on the threads when installing the head bolts.
None of the head bolt holes enter the water jacket, so no sealant of any kind is needed on the head bolt threads.
Good luck!
-Steve
