2f fluid heat riser install
Denver
On order is a set of headers and fluid heat riser from JTO. I am starting to research on the riser install and haven't found much. Guess they may come with some instructions but figured I can get a head start and not be blind sided when a box of parts shows up and nothing else inside. Who's installed the riser on a 2f with the oil cooler setup? My 40 is a 7/70 with a 1980 something 2f from a fj60 I think.
Where do I tap into the cooling system?
How did you route the lines?
Any tips or tricks?
Any info would be appreciated, thanks
use the line that goes from the rear of the DS head to the fire wall. It is pretty simple once you have the parts. I posted pics in a similar thread a week or two ago.
i bought a header and heat riser from MAF.. they actually recommended it with those headers.. and the damn thing didn't even fit. Even in the coldest temps my cruiser starts right up and idles/drives fine... not sure it is required with a well running engine but it definitely can't hurt
Ok saw your pics it all looks nice and clean. I have a pretty good grasp on how and where it goes under the carb. But it's not clicking on your description where you hooked into the system at. Can you post some pics on the other end of it all?
I heard there's sometimes a little grinding that is needed. Such a pain for something that's suppose to fit in.
just finished doing this with a kit from MaF, I disconnected the hose that runs between the back of block vertical brass tube and the the heater valve mounted at top of firewall, used that as the supply and return loop, i am waiting to see if the gasket supplied will provide a waterproof seal, similar construction to a head gasket, thick metallic type with semi perforations in it. It will be at least a few more weeks until I can test it as I am in the process of putting everything back together.
