For Sale 2F engine
Status
Not open for further replies.
Running 1979 2F engine. A couple smog tubes are broke off. Done a compression check with a real crappy gauge. All were 90-110 depending on how well I got the gauge to seal. Did not do the ones with broken smog pipe. Original carb needs rebuilt. Factory power steering pump included. New fuel pump. Intake manifold is not cracked. Has dual pipes on exhaust manifold. Has oil cooler and new water pump. Some smog equipment will be included. Has a 4 speed bellhousing and clutch set up. I will put as much extra parts as I can fit on the pallet. Alternator, starter and brackets do not go. I need them for my new F.5. Can deliver to Fastenal. $650.
View attachment 1579097 View attachment 1579098
Do you have transmission and or transfer case as well?
Where are you located?
Status
