2F Engine Gone?
Escondido, CA
Went on a road trip this weekend with my FJ40 and the damn thing died on the side of the Interstate.
It was driving along fine at 65MPH, normal oil pressure and temp when it suddenly let out a huge backfire with flames and promptly quit.
I tried to start it again, but nothing but huge flames out the arse when it turned over. Since it happend late at night in the middle of nowhere, I haven't had a chance to have a good look at it.
Any ideas on what the hell happened?
yeah doesn't sound like the motor............carb maybe(or the above)
You don't have a DUI distrubutor by any chance? As already said by most above, look to the distributor.
Cam could have broke, or maybe dropped a valve, but less likely. Not carb related.
I did the HEI distributor swap several weeks back. Used the gear from the original distributor, so should be alright.
It's sitting in a tow yard in Canada at the moment. I'll have to head back next week to work on it.
What would be wrong with the HEI distributor?
Using a Toyota gear as you did is good as I think that the bulk of the DUI made distributor problems are a result of the gear which they supply, or used to supply (it's supposed to have been updated now). But problems can also come from the setup = the placement of the gear on the shaft as described in tech sect links on the subject. You should definitely pull it up to have a look but it's not a given that because you did the change it is the source of your problem.
Could the distributor clamp been loose or not set up to work well?
OH OH................ :doh:
why do folks keep using this crap?
I have a nice Delco Remy timebomb dizzy if someone wants to kill their cruiser.....
I used the Toyota OEM clamp on the new distributor. It nay have worked itself loose as it does not sit flush on the distributor.
I pulled the distributor out of an old Camaro with a 256ci engine and replaced the internal electronics with new. Could the distributor shaft/bearings have seized/malfunctioned?
