2F cam bearing question
I just had a local machine shop press new cam bearings into my 2F engine block. The new bearings have holes in them for oil to get to the cam. Only some of the bearing holes are alligned with a coresponding hole in the block while others have no coresponding opening in the block to allow oil flow. Is this a problem? Did the machine shop press the new bearings in wrong or mis aligned? Thanks in advance for any help.
Welcome.
None of them line up?
Which ones line up?
Have you used a mirror and light and also an angled pick to make sure that they are or are not lined up?
2F cam Bearings
Thanks for the reply and welcome. I just went out to the garage, the specifics are as follows:
1st bearing (closest to timing gears) this bearing has 1 hole and it does line up with a coresponding hole in the block.
2nd bearing has 2 holes but only one of them lines up with a coresponding hole in the block.
3rd bearing has three holes but only 2 of them line up with holes.
4th bearing (closest to transmission) has just one hole and it does line up with a coresponding hole in the block.
Thanks again Poser!
In a 2F engine:
Number one oils the cam and bearing at that journal, and also provides oil to the cam gears up front via the passage and oil nozzle in the end plate.
Number two oils the cam and bearing at that journal.
Number three oils the cam and bearing at that journal along with providing the pressurized oil to the rocker shaft assembly via a head bolt and passage in the head.
Number four oils the cam and bearing at that journal.
Sounds like everything is installed correctly.
:beer:
