- Joined
- Aug 27, 2013
- Threads
- 5
- Messages
- 9
Hi all,
I've got a 2F forklift engine with an Impco CA125 propane carb on the forklift manifold - 70mm bolt spacing with a ~43mm hole. This is a bit bigger than the propane carb that came with the engine.
I need to add a second butterfly valve. Ideally it'd have the 70mm bolt spacing top and bottom, so I could put it between the manifold and existing carb. Having to do some machining is ok. I've got 6", maybe more, to work with.
Does anyone know of anything off the shelf that will fit the bill?
Thanks in advance!
Thanks in advance!
