275/55R20 Goodyear Duratracs on LX570 20’s
The Kevlar sidewalls are appealing to me based on the 20" rim.
I really want the best of all worlds. Speed, snow, and noise.
Wrangler Adventure with Kevlar.......the kevlar spiral wrap is in the TREAD. But, the sidewall uses special compound call “DuraWall” that helps with puncture resistance.
You can see that the DuraWall actually does work in improving sidewall strength!
P-metric Adventure only has one layer of Kevlar. LT has two i believe.
IF Goodyear makes this tire in LT285/60/18 (stock LC size), then i would seriously consider this vs. KO2 that i have now. But then again, i just don’t have a cozy feeling with Goodyear quality for some reason.
Why not a Goodyear fan?
I searched for a post on the Wrangler Adventure and didn't come up with anything so I moved on to the Goodyear Duratracs but you may have a good point with those tires.
I don’t know. Just from reading around the net. I trust Michelin, BFG, and Yokohama. Just personal bias. Not sure if I have facts to back it up. 😁
I just put a set of 265/75r16 on my taco , mounted on factory aluminum rims and stock suspension , I have not used Goodyear in a while but prefer this tire over a BFG .
Not sure if I am going to put the Duratrac on my LC , planing on a lift for my 2019 over the winter , I have run the Toyo’s in the past , they are a better tire IMO but do wear a bit faster .
