24v fuse box 12v system
St Anthony, ID
24v fuse box 12v system help please
The PO of my 40 put a 24v fuse block in, but kept the original system setup. He said that he did so because he was going to be running stuff like a winch, wheeling lights, onboard air, etc. the problem is that it has burned through a couple of alternators. has anybody done this kind of mod successfully? is there anything i can do to keep the wiring set up without changing the fuse block? or do i just need to suck it up and change it back to a 12v system? thanks.
Typically 24 systems run smaller guage wire due to half as much amps. needed to run the same accessory. If the wire is guage is too small it can cause too much resistance and burn things up. Check and make sure it is the right size of wire for a 12 volt system.
thanks. i'll do that. i forgot to add that this is on a 350 conversion. sorry bout that.
I'm not sure what the difference would be solely in a "24V fuse block." The block itself would be solid metal circuits? I don't recall noticing a difference between my '79 FJ40 and BJ42 fuse blocks but maybe I'll take a closer look? I can see if the system was all 24V like what BJ-44 is alluding to.
Though their site is fairly lame at the moment, wrangler power products (wranglernw.com) has some great fuse blocks if you are looking. I got a 9/3 split block for my V8 truck and they carry lots of sizes and combinations. Wish I could send you a link but what is listed for their products is very minimal at the moment. Give them a call.
I have done the first steps to recovering from a rat's nest of crazy runs and too small gauge wire on the 45. I bought a terminal block from wrangler to start and some varying gauges of fuseable link. Everything is soldered and heatshrinked. No more borrowing and splicing into wires.
Here is a similar terminal block to what I got-
http://www.madelectrical.com/catalog/cn-1.shtml
