24 gallon subtank install etc.... HELP & ADVICE
long story short...my oem subtank is leaking and so i've looked for an upgrade and found that "long range automotive" in oz still makes a 24 gallon replacement subtank, with trading emails back and forth, i still have a few questions.....hope you guys can help
first off when i did the subtank install i went the oem setup the same as elmarchi etc...withall oem parts....my question then is "as i am not that mechanically inclined" is that long range has a "kit tank" and just the "tank" itself. the tank itself is design for the oem setup with the toyota sending unit,
Am i running the toyota sending unit? i assume so..is it not the 2 wire sending unit thing? and my last question is...and i'll quote from his email.....
[COLOR=navy]Is your vehicle running the 4500 petrol engine? If so then you will need to extend the float arm on the sender unit and the fuel pump shut off switch float sensor,
[/COLOR]
so is it the 4500 petrol engine in my cruiser ie the 1fze, and how do you modify/extend the float arm on the sender unit and fuel pump shut offswitch float sensor
also has anyone run this tank and how it mounts etc....
words of wisdom would be appreciated
matt
[/COLOR]
matt
