Check your cylinder compression numbers and see if one is low.
I've done that too. I'm really puzzled over this oneyes,
check the pcv and tube also.
Back pressure is present with the description you gave us.
Check for a burnt valve and or bad rings. You said you know it has had low compression for a while, recheck and see if it changed drastically.
A few things come to mind here to get you by for a while.
I'd replace the Harmonic Balancer and the Front Main Seal with a "Toyota" seal. Buy a sleeve for the crank. Use some emery cloth on the crank, next coat it with a thin layer of RTV, than slide the sleeve on. This will make a tight fit for the seal. Than replace as norm the seal and H/B.
Replace your PVC again. Cleaning out an old one is useless after that much back pressure. If you find the pressure to high you could always run an open vent and bypass the PVC.
That will hold for a while till you can dig deeper into the engine.
