- Joined
- Jan 13, 2009
- Threads
- 3
- Messages
- 7
I'll keep the chit chat to a minimum-
I'm trying to put an '85 back together. Purchased pretty cheap with a blown head gasket, P.O. drove it (knowingly) like that for a while
- it sat for a while before I bought it.
I tore the whole thing down, took the head, block,and crank to a machine shop for work.
My head has two cracks in it so, will an '83 head fit an '85 block? If I can swap the '83-'85 heads, how much of the '83 has to go with it?
My cylinders might not be able to be cleaned up by being honed, the guy at the shop said maybe bore it out. He was talking about .030, .040, and maybe .050 as boring options. What is "common" and can I re-use my old pistons; just get new rings?
My crank was "well within specs." and is just going to get polished
The '83 truck (for reference and parts) is a 2 wheel drive, the motor starts-won't stay running on its own. Has low compression in the 4th cyl. (probably Head Gasket?) Would I just be better off to swap the whole '83 motor into the '85?
This is my first attempt at something like this and don't know if the original block cleaned up, bored over with an older head would be a better route than a straight up swap.
I did search, different sites too. I contacted Ted at engine builder when I was looking for a complete gasket set, he was helpful. I just want to make sure I have (most of) my chit together when I call him back to get more parts
Thanks for any help or extra input.
Take care, Hoss
- it sat for a while before I bought it.I tore the whole thing down, took the head, block,and crank to a machine shop for work.
Take care, Hoss
