22r carb, 20r intake and head, 22r block, VACUUM NIGHTMARE11
Piedmont, SD
sooo
I have a 22r block with a 20r head and intake and a 22r carb. Baught the truck with the work done but not finished or ran yet, vacum lines arent hooked up at all. Ignoring emissions, which friggin vaccum lines go were?!?!
Is ther a combination of diagrams to use or what. If it was just a 22r carb with a 22r intake i could use a diagram but i dont know how to mahs the two together any ideas or write ups on this?
might get a hold of dusty here in town. he knows alot about those motors.
and for a 12 pack pull it up next to his and copy the lines.
check for him on the black hills 4 wheelers site.
I would, but the bh4wheelers forum is broken or something. I have been trying to register there for almost two years and it hasnt worked.
An FSM should be in the FAQ...
Or just block them off... I've been told drag racers used to take the vac advance OFF Chevy small bock b/c it ran better of some stuff... It will run w/o the advance... Everything else is emissions IIRC...
not sure why some people get locked out.
we had a hacker that toasted some of that.
if you had just reg, he smoked ya.
email the admin at
jeepcj776@rap.midco.net
he will fix you up.
include user name.
sweet, thanks, ill check it out and email him.
it will run but not well.
the drag racers set the advance or lack there of for 10,000 rpm assaults that last 10 seconds with high octane fuel.
won't work on the street the detonation will destroy the motor in short order.
