Not a hassle at all. Rail hate drops no problem. On this road trip I used the tail gate as a diaper changing table.I was always very happy using a big Thule box on the roof.
Those of you with hitch mounted options doesn’t it make getting in and out of the rear cargo area a hassle? We usually keep our soft sided duffel bags with clothes and other camp gear in the roof box that way it only needs acccessed once per day. The rear cargo area gets accessed every stop.
As a start, here's some "required reading" fgor anyone running the 17" TRD Rock Warrior wheels: https://www.toyotapartsdeal.com/installation/40362D86F9D917D98825767800785BB2_Tundra_Sequoia_Land Cruiser TRD Alloy Wheel PTR45-34070-34120 IssF.pdf
You will note in that poop sheet that Toyota recommends LT285/70R17 tires. That setup will not require a lift or any other measures to run without problems on your LC200.
The Cooper Discoverer AT3 XLT tires are available in size LT285/70R17 121/118S Load Range E: Cooper Discoverer AT3 XLT | Cooper Tire.
Be careful, there are other Cooper Discoverer AT3 tire models available in P285/70R17 that are NOT recommended - LT285/70R17E 121/118S AT3 XLT tires are recommended.
And just in case you do go with that setup, the Recommended Cold Tire Inflation Pressure for the LT285/70R17 121/118S Load Range E tires on your LC200 is 40psi F/R.
I would also highly recommend 5 wheel/tire setups not just 4. This not only allows you to do a 5-tire rotation, but also assures you will have a fully capable/compatible spare that you could use with confidence for long distances - just in case a tire shop with the correct tire is not available close to you should you need a rfeplacement.
Hope your trip is rewarding - sounds like a good one!
HTH
Hello @gaijin , would 40PSI be the same recommendation for an LX on the Cooper Discoverer AT3 LT285/70R17 121/118S load range E?
Thanks!
No.
The RCTIP (Recommended Cold Tire Inflation Pressure) for the Cooper Discoverer AT3 LT285/70R17 121/118S load range E tires on your LX570 is 35psi F/R.
HTH
Thanks for the answer Gaijin. Just curious why the psi would be different for the LC and LX when the tire is the same (unless I'm misreading the post)? I realize that the stock weight of the LX is 180lbs over the LC but didn't think it would make that much of a difference. However, I'm not the expert which is why I'm asking. Not doubting, just curious.
I run an oddball tire that isn't on any charts.
yes, the infamous LT275/80r18. Load 129. Max psi 80. On my rig it feels best around 34-36, but the heat test puts it at 36-38.I'm curious - what tire is that?
