2018 LC high beam sense wire
Boulder, Colorado, USA
Hey all,
I'd like to set up my light bar so that when I turn it on, it only comes on with high beam on the headlights. So I'm looking to tap a wire that gives me switched 12V in accordance with high beam. I'll run that through my light bar switch to the relay that powers up the light bar.
Can someone point me to the wire I seek? I'm not well versed in LC wiring, so photos would be a huge help.
Thank you!
Aha! Found what I sought, on the fuse block. Now I have the light bar only coming on if the high beams are on. Great!
For anyone coming along after me, discovering this thread, simply tap in to the fuse for either right or left side high beams, in the fusebox next to the battery. That gives 12VDC when the high beams are on. Use that to run through the light bar switch, to the relay that turns on the light bar. Pretty simple.
