2017 lc200 yaw rate location ?
Lamballe, côté d'Armor, france
Hello,.. Sorry for my English, but I'm French.. I need help for 2017 lc200 with vsc system..
I have to change the yaw rate sensor, but I can't find it.. On the older model, this sensor was near the airbag calculator, but not on this model.. Thank you..
Why do you need to change (replace) the sensor?
I have "bad value" see in techstream.. Sometimes, "acceleration" values are out off range, sometimes I have a "can bus communication defaut" with yaw rate and G sensor.. Initialize it is sometime very difficult.. I think it's just poor connection with sensor, but I can't found it...
Thank you, but not in this model.. I've already seen this sensor under the center console for the véhicule under 2017 or for the véhicule without vsc.. I've removed the center console, there, 's no sensor...
If that's the case, you might need to spend the $15 on a 3 day GSIC/TIS membership so you can get access to the docs specific to your VIN
I've found where is now the yaw rate sensor.. It's integrated with the airbag calculator..
The electrical wiring is also very different with the old lc200. If someone have the new lc200 schematic... Thank..
The latest I have access to is 2014. Anything newer and you might need to spend $15 for 2-day access to the GSIC
