2016-2019 TRD Brake Pads?
Albuquerque, NM
My 2018 with 17k miles pulsates when you touch the brakes at highway speeds, and less so at lower speeds. So, obviously it has warped rotors. I've had to stand on the brakes a time or two so I'm not surprised they've gotten hot enough to warp.
The dealership is turning the Rotors under the warranty and has offered to replace the pads while they're in there for just the cost of the parts, $90, which I think is very nice of them.
I asked about TRD pads and they said there is no such thing for an '18 Landcruiser. I said, aren't they the same as the Tundra or Sequoia? He checked with the parts department and said they are not the same. He said there is no TRD brake pad listed for the Land Cruiser after 2010 and no TRD anything except air cleaners after 2015.
I searched the threads here for the TRD front pad part number and all I found seemed to apply to the pre-2016 version. By the time anyone responds to this, it'll be too late for me. But if anyone knows the TRD part number for the '16-'19 model years, it might help someone else down the line.
They say that but the TDR fit perfect.
I did some research back when they had the 40th anniversary sale and found out they fit. I have the 2016.
I put them on and they allow it to stop way faster. It's really noticeable.
The down side is they have an incredible amount of brake dust.
Now I wish I had stocked up on them.
I ordered these part numbers.
TRP BRAKE PADS - REAR PTR090C110
TRP BRAKE PADS - FRONT PTR090C111
Another quick way to check is to cross reference model year OEM part numbers. In this case, the 2018 OEM brake pads are the same part number as the 2010 OEM brake pads. So TRD pads listed for the 2010 should fit fine.
Which dealership did you go to?
