2015 GX460 TPMS reset
Malleus
contact@RESTORE4x4.com
Supporting Vendor
Charlotte, NC
OK, I'm stumped. There is no reset button like the 200s have, under the dash. There is also no TPMS page on the multifunction screen.
Is there any way, short of me pulling out the laptop and hunting through TS, to reset this thing?
So, no joy?
There is no reset far as I know.. They are either working, not working, or you have a low tire. Did you check the spare?
If you have all 5 tires set to the proper PSI and still get a light after driving a bit, then you have a bad sensor and itll need replaced. 10 or so years is a good long run, so not uncommon.
Most tire shops will check sensor function and replace them for around $70-100 a sensor. If the TPMS light is on, you either have a low tire, a sensor with a bad battery, or a low sensor. It's cheap enough that I don't mess with them myself and just have the tire shop do it.
