Hi folks! Been mining the AHC threads here (thanks especially to the Augmenting for Load and Height Modifications threads - most of this plan comes straight from them).
My truck: 2011 LX570, 172k miles, AHC/AVS, no KDSS. Falken Wildpeak A/T4W LT285/70R17 Load Range C on Icon Vector 5s. Slee sliders, Prinsu rack, drawer system in back. Payload runs rear-biased: gear, drawers, hitch-mounted dual dirt bike carrier on weekends, family trips with 4 people. Loaded trips pencil out at 1,200 - 1,400+ lbs of payload. 90% on road, 10% off road (some technical).
AHC history: Flushed at 147k. Globes are original. Planning to flush again in the next 5k miles.
The plan after service:
Where I'd like a sense check:
GRUMVEE
- Sensor lift: ~1-1.25" front, ~0.25-0.5" rear. Keeping some residual rake so it sits level loaded. Techstream HOU to fine tune, zero point and G-sensor reset, retorque at new height, then alignment.
- OEM front top-hat spacer (43136-60020) for droop and front pressure margin.
- Rear coil spacer sized per the "sensor lift + 10mm" rule of thumb.
- Possibly new rear bump stops (originals are 15 years old).
- What size rear spacer, and does it matter that I can't find much between 15mm and 30mm? The formula points me to right around 20mm, but the off-the-shelf poly options I'm finding are 15mm (Dobinsons PS59-4006, SuperPro SPF3287-15K) or 30mm. Is 15mm enough for a sensor-lifted truck carrying 1,400+ lb rear-biased, or do I need to go 30mm and deal with the consequences?
- What are people actually buying and installing? Seeing a mix: Dobinsons 15mm poly cross-fit from the 100-series, SuperPro, generic eBay aluminum in 20/30/40/50mm that needs the ID machined for the bump stop taper. Anyone found a clean 20mm-ish rear spacer that fits the LX570 cone bumper without modification? Also - Dobinsons says do not stack their spacers, but I've seen 2x10mm stacked here with one above and one below the isolator. Which is right?
- Coil bind and bump stops. Dobinsons warns that spacers can bring on coil bind before the bump stop engages. At what spacer size does this actually become a concern on a 200, and does it change what bump stop I should run?
- Anyone actually carrying 1,400+ lb on a sensor-lifted truck with spacers only? I've seen 1,800-2,200 lb numbers cited, but I think those setups are running airbags as a helper. Trying to figure out what spacer-only realistically supports before H-mode gets flaky.
- Globes are original at 172k, no leaks, transitions feel normal. Is there a way to assess them short of replacement, or is age alone the trigger?
- Anything in this sequence you'd change? Especially interested if anyone's hit the over-spring problem (too much preload, mushy damping, Low mode issues).
GRUMVEE
