2011 FJ C rear driver side axle instalation
Austin
According to Nitro Gear they’re AX T60240 axle shafts can handle larger tires and the stress of off-roading better than OEM axles. I can’t find any reviews on these axles so to those who’ve had axles from Nitro Gear what do you think about them? I also need to know if I need to change the size of the seals when I do the install and if there’s anything I should know before installing...
Thanks
If they fit the same OEM hub assembly, then the seal shouldn't change.
