2010 ACH Bleed Procedure?
Birmingham, AL
Website
www.overlandtailor.com
Wife's LX570 needs a front shock replaced and can't seem to find a bleed procedure for the 200 Series...
I know you guys eliminate the ACH whenever you can, but wanted to see if someone can help before I pay someone else for this...
Best regards,
john-
The procedure is very similar to the LX470. Add fluid to the reservoir (behind the passenger rear wheel) and open the bleeder screw at the corner you replaced. The suspension will settle as you let fluid out, stop before you hit the bump stop. Start the engine and let the system raise the car back up, repeat until air stops coming out. If you want to bleed all four corners, the order is front right, front left, rear right, rear left.
SUSPENSION CONTROL: SUSPENSION CONTROL SYSTEM: BLEEDING (2008 LX570)
AHC fluid (LX 570) flush DIY help?
Thanks so much for posting that... I would just rather do it myself, but the $200 labor for that is a nice bonus... Thanks again for taking the time to post the bleed procedure.
Cheers -
John
