From those photos, it looks like at one point it was heavily rusted and then coated with something to either slow further rust or hide what is there. Some work, especially suspension work, may be difficult because of the rust. I doubt the KDSS shutter valves can be opened easily (necessary for some suspension work) and I wonder about being able to do an alignment.
The exhaust pipe on the front passenger side of the muffler looks like it has a rust hole. Since that’s part of the muffler, it will need to be replaced if it is holed. Not sure why the other pipe into the muffler has new bolts?
The front engine undercovers are missing (probably all 3). There should be 2 metal ones up front (left and right) and a large plastic one toward the rear.
If I were buying it, I would get under it with something like a screwdriver and poke around a lot to check on extent and depth of the rust under that coating.
