I recently purchased a 2011 that only has 1 key. Everything on it works.
I ordered a key from Amazon that claims to fit this - which it did not.
My key is a HYQ14AEM and the replacement sent was a HYQ14AAB.
Ok, the seller didn't have a listing forthe correct key so I sent it on it's way.
I contacted UHS Hardware as they advertised the correct key in a less expensive aftermarket version.
I called, verified the FCC ID and even the 4 digit 6601 code inside.
Got them (2) today - Techstream had no problems registering them.
Except the rear hatch doesn't work. Does on the original key, not on either of the new.
I can lock, unlock, roll windows down, remote start, and proximity picks up on it with the new keys. I even tried changing the pattern from long pause to double click and, again, original key works - new do not.
Has anyone purchased any aftermarket keys that work? Anyone else seen this? If so, where?
