2006 landcruiser steering
oklahoma
does anybody else have problems with steering ? has been aligned several times.still pulls left or right whenever it wants.
Wide tires and asphalt roads with the worn "ruts" where all the vehicles drive will cause your vehicle to want to climb out of the ruts either left or right depending on which side the front end happens to be up against. Could be something else but my 40 wanted to do that until I got everything tightened up. Don't notice it with my 100
Straight line road cruising, or under braking?
What tires are you running? And the tire pressure?
And has the alignment been complete including caster & camber?
straight line cruising on asphalt,concrete,interstate concrete.does not matter.steering has no neutral return position.tires are michelin,pressure set to vehicle specs,. constant fiddling with steering wheel.alignments were done at toyota dealerships,chek all parameters.swapped tires. i think it is an artifact of the independant suspension and power steering.car has 200000 miles under her.
I've got the same issue and all of the usual culprits like the crown in the road and alignment / tire problems are not the case. I am replacing the steering rack and tie rods this weekend.
It seems to have play in the bushings and also when turning right the wheel doesn't really re-center itself.
ok let us know how that turns out. have a feeling i am headed in the same direction.
