Hi all,
I'm having an issue with the instrument cluster in my 2006 Land Cruiser 100 series (HDJ100, 4.2L turbo-diesel, LHD, EU-spec, VIN: JTEHC05J50402....). Hoping someone here has seen something similar and can point me in the right direction.
Problem description:
Has anyone experienced this exact combo of symptoms on a 100 series, especially the diesel models? Any common fixes, DIY tips, or recommended parts/specialists (I'm in Europe, so EU-friendly suggestions appreciated)?
Thanks in advance for any help!
- When I turn the key to the ignition-on position (without starting the engine), none of the warning lights come on at all (e.g., no bulb check sequence).
- Specific examples: If the fuel tank is empty/low, the low fuel warning light doesn't illuminate. When I engage the diff locker, the indicator light doesn't come on.
- However, the main gauges work fine: speedometer/odometer, tachometer, and temperature gauge all function normally.
- When I turn on the headlights, the headlight indicator light does come on, and the turn signal indicators in the cluster work as expected.
- Additionally, my horn no longer works. The buttons on the steering wheel (like cruise control or whatever else is there) are non-functional and don't light up anymore.
