2005 GX470 Mark Levinson Amp Wiring Help
San Diego
Hey guys,
I'm adding a small powered subwoofer (Kicker 46HS10) to my 2005 GX470 Mark Levinson Navigation system and could use some help regarding which wires to tap. I've searched everywhere and can't seem to find a definite wiring diagram for the ML amp. The colors on the wiring diagrams i've found don't seem to match up perfectly to the amp on mine, and thus i'm hoping someone here can confirm which wires are which. Does anyone here know which wires are the output for the subwoofer? Im mounting the shallow sub directly next to the amp under the drivers seat, so i'm just going to tap them right at the output harness. I believe the black/yellow, and red/white pairs are for the rear speakers, so I may just try those, but i'd rather do the subwoofer output incase any low frequencies are rolled off to the speakers. Also, which wire would be the best/easiest to use for remote turn on? Any insight here is greatly appreciated! Thanks in advance.
Hey guys,
Did you get this figured out? Do you know the watt output of each channel including the sub?
Yup I wrote out instructions here and labeled the wires. Not sure exactly about wattage though.
