I am chasing a specific and frustrating engine issue on my 2005 Lexus GX470 (4.7L V8 2UZ-FE with VVT-i). I am hoping some of the 2UZ experts here can point me in the right direction.
The Symptom:
The truck experiences a distinct power surge/hesitation/hunting sensation under acceleration, but it only happens within a narrow window from 1,900 RPM to 2,900 RPM.
What I’ve Noted So Far:
My Leading Theories:
Given that this 1,000-RPM window is exactly where the VVT-i engine transitions its variable components, I suspect the issue lies with one of the following:
Thanks in advance!
The Symptom:
- Below 1,900 RPM: The engine runs perfectly smooth. Low-end torque is great, and idle is steady.
- Inside 1,900–2,900 RPM: The power fluctuates rhythmically, almost like the engine timing or intake air path is constantly switching back and forth or fighting itself.
- Above 2,900 RPM: The surge completely disappears, and the truck pulls hard all the way to redline.
- No Check Engine Light (CEL): The dashboard is clean, and there are currently no active or pending diagnostic trouble codes (DTCs).
- Not a Total Component Failure: Because it clears up completely past 3,000 RPM, I am fairly confident I can rule out global failures like a dying fuel pump, failing ignition coils, bad spark plugs, or a skipped timing belt.
- VVT-i Oil Control Valves (OCV): Sticky solenoids or clogged micro-mesh filters inside the cylinder heads causing the cam timing to "hunt" under load.
- ACIS (Acoustic Control Induction System): A sticky intake manifold butterfly valve, leaking vacuum pod, or failing Vacuum Switching Valve (VSV) malfunctioning during the short/long runner transition.
- MAF Sensor Load Miscalculation: A dirty Mass Air Flow sensor failing to accurately read sudden air velocity changes during mid-range RPM transitions.
- Torque Converter Shudder: A slipping clutch in the A750F 5-speed automatic right around cruising speeds, which can mimic an engine surge.
Thanks in advance!
