2003 Seqouia Question
They have drains that run down the A post and to the ground, if the tube is bad it runs inside.
most likely the sunroof drains.. try pooring some water on the sunroof and see if it drains out from under the vehicle. Like stated above there is a tube at each corner of the sunroof above the headliner for draining. most of the time the drains get clogged, sometimes the tubes come off... If it is the drains, it can be missleading because the water will drain down the top of the headliner, down any of the pillars, into the floor.... Good luck
