2003 Driver's side high beam bulb replacement.
Columbus Ohio
Knocked out changing the low beams, and passenger side high beam and now stuck on driver's side high beam. Between the windshield washer intake tube and various assemblies, I can't get enough leverage to remove the harness from the bulb or the bulb from the projector housing. I don't know the last time they were removed, so they may be pretty set in place, but as is, either my hands are too big, too weak, or I am missing a trick or a step to get access. Any help is welcome.
On my 05 the filler tube for the washer fluid easily pulls up and out. Also loosen / remove the battery tie down to be able to shift the battery around a bit to allow some more space / access.
IF those are a no go - battery removal as suggested above.
