2003+ Anarchy NAV Delete CarPlay/Android Auto Head Unit Discussion
Based on @Anarchy 's input on the cheap Android headunits with the integrated bezel, I ordered one of those today & will develop a bracket for it that'll tie it into the steel stereo/head unit 'rack' behind the dash, rather than just letting it hang by the (apparently somewhat flimsy) bezel connection points.
As the community downselects to a few common options, I'd be more than happy to develop additional brackets as needed to support a handful of radios.
Honestly, a standard double-DIN support bracket would be ideal for me. I'm so sick of screens everywhere I want to drop an old single or double DIN head unit in there and call it done...
Since I'm running my HVAC Module now, I'm looking at audio system upgrades in the coming weeks without breaking the bank.
For those running Teyes/Phoenix/Android headunits; if your audio system has gotten rid of the ML Amp, what aftermarket amplifier + speaker + subwoofer did you wire in?
I have the Phoenix head unit and did:
-Infinity Kappa 603CF up front
-Infinity Reference REF-4032CFX in the rear
-Kicker CompRT 48CWRT674 sub in the OEM enclosure
-Pioneer GM-DX975 5-channel amp
-AudioControl LC7i line output converter
I seriously considered going with a 3-way Focal setup, at least in the front, but eventually talked myself out of it for budget reasons. I might go back and add the midrange Kappas in the front when I get the headunit squared away. Probably looking at an eventual redesign of the subwoofer setup as well, but this was a fairly inexpensive solution in the meantime.
The Phoenix was already installed when I bought it and did not have the RCA-out harness, and I have not been able to source one, so I'm stuck with line-level outputs. The audio is still lacking in a lot of ways, the LC7i was an improvement but not a solution. I don't know if the RCAs would make a difference or if its just the headunit itself, but it makes me wary of any of the generic android headunits in the future.
I've just started looking into head units so I don't have any contenders yet, but it'll most likely be a double-din unit. My main requirements are audio quality and screen brightness. My biggest gripe by far with the Phoenix has been that the screen is practically unusable when its sunny, despite full brightness and an anti-glare protector. It might as well be off if you're wearing polarized sunglasses. The OEM screen in my Transit is clear as can be even in direct sunlight and wearing sunglasses, so I know its possible from a technical standpoint.
My thoughts were something like the Kenwood DMX9724XDS. It’s a 10.1 inch floating screen so it would in theory cover most of the opening and possibly wouldn’t require any special trim pieces. I’m looking for wireless CarPlay and would like to upgrade the rear camera and possibly add a front camera.
My concerns would be the wiring. I would want something that would plug into existing wires rather than cutting and splicing. Not sure if wire adapters exist or if it would have to be made.
i have this one and love it... has four camera inputs as well
Found a new Alpine S2-A55V on marketplace for $200. OEM ML Speakers & ML Subwoofer for now.
I initially just planned on chucking this after market 5 channel amp under the passenger seat and calling it a day.... But that sorta seems lazy when I literally have a business, that among other things, makes brackets. 😂
Forgot to grab pictures with my amp & GMRS radio body in place before starting the paint process, but check it out! Super study, once everything is mounted up securely it all still clears full seat adjustment. Not too shabby!
Forgot to grab pictures with my amp & GMRS radio body in olace before starting the oaint process, but check it out! Super study, once everything is mounted up securely it all still clears full seat adjustment. Not too shabby!
View attachment 4213442View attachment 4213443View attachment 4213444
With the LJE logo and everything! If that's something you decide to start selling (and if it'll work for the LC) I'll definitely pick one up!
Each LJE logo a person has on their vehicle is +10HP (at this point, I'm driving a supercar). 😆
Should work just fine for the LC. I yanked the amp, nav computer, and back up camera computer (yes, there's an entire computer just for the backup camera) out from underneath the seat. There's actually a decent sized cavity underneath the bracket, so that should help with keeping the wiring reasonably clean. I should also be able to help folks figure out what amps would fit down here underneath the seat as well!
Do you already have Anarchy’s NAV delete installed?
Yessir - I did the mechanical reverse engineering of the OEM cassette player faceplate (lots of weird curvature!) & now Anarchy & I are working on fine-tuning the mechanical design of the replacement faceplate, with the goal of replicating the premium fitment & feel found in the rest of the truck.
I've got prototype #2 in my truck.
I'm in for one of those brackets... Is that a 2m radio sitting next to it?
What are the dimensions on the bracket? My amp is just sitting loose under the seat. Never had a problem but I wouldn't mind securing it
“Final” selection…
10.1” Android Head-unit (eBay): $194.40
Alpine S2-A55V (FB Marketplace): $200.00
Infinity Primus 603CF (Crutchfield): $129.95
Pioneer TS-A1081F (Crutchfield): $89.99
Kicker 48CWRT672 (Crutchfield): $116.96
Total: $731.30
Installed, massive improvement and very happy with it… I wish the subwoofer had more thump - but I’d rather leave the smaller factory sized sub than put in 2 x 10-12”.
Jealous! I'm still rolling with the ML setup, which took a little thinking due to the way they split out the front door speakers.
I wired the front/rear door woofers in parallel (so front left/rear left in parallel, front right & rear right in parallel), which gave me something between 4 & 6 ohms per side.
The mid range & tweeter on the front doors come wired in parallel (8-ohms ish), so I connected those to the 2x channels on the amp & set the highpass to 500hz to protect them.
It works, but I feel like it's a little muddy. Probably no worse at all factory, but I'm just paying attention now. . .
Question for you @Anarchy - was your sub wiring a little weird? My EWD shows 4x wires going to the sub, but I know only 2x are used in my year (05). What was weird is that they weren't from the same twisted pair as I would have expected.
Yeah it was weird on mine on the ‘06, four sub outputs shown from the ML amp, but some of them actually use WFR+ and WFL+ as the two active sub wires, basically bridging the two sub channels.
Yup, that's exactly what I had. Threw me for a loop since I had previously replaced my sub but couldn't remember any details. I've got a drawer system in the back too so I couldn't just pop the panel off to look 😂
So - I think I've tracked down the connectors I'll need to make a easy harness to interface a new aftermarket amp to the stock speaker harnesses - in a LX, the speaker connections get split across three different connectors! Annoying, haha. I assume the LCs might be a little different, so I'll have to repeat the exercise for those.
I'm also trying to become a SoundStream dealer so that I could offer the 5-channel Picasso Nano amp as a bundle option. It's relatively inexpensive & I think would work well for a lot of folks. Obviously, some people will want a fancier amp - that's totally cool too, that's why the amp will be an optional part of the bundle!
I'm thinking at the moment, the bundle would look like:
  • New amp (optional)
  • Amp-to-speaker harness (optional - someone super serious who's replacing speakers too might want to run new speaker wiring entirely)
  • Amp power wiring harness
  • Amp mounting plate
  • Head unit brackets (tie a new head unit/bezel into the steel cage that everything mounts to)
  • Head unit to amp RCA cables
  • New backup camera
  • New backup camera mount.
  • Heater duct extenders to redirect the rear heaters from blasting the amp area to actually pointed at the rear occupant's feet (these already exist here)
Most of that work is done - just need to continue integrating mounting points for various amps onto the plate so that people have easy options & confirm the harness connectors I ordered will fit the stock harness.
It's coming together!
