2002 Sequoia electrical gremlins! Fixed!
Illinois
I purchased this truck with a blown head gasket. The PO drove it without coolant for an impressive amount of time. Got to say these 2UZ are tough engines. I found an engine from a 2003 Tundra and swapped it in. Before I put the engine in it would start up and run poorly but other than that it was normal. Now after putting an engine in I have no speedometer, 4x4/center diff lock lights flash and it won’t start unless I ground/jumper the starter relay. I have been over and over the grounds and fuses. I made sure everything is hooked up just the way it was. Anyone run into this before? Any thoughts? Thanks!
