2002 LX470 - roof rack cushion replacement
Atlanta
I have an early 02' build LX470 with the obscure/hard to find roof rack cushions/insulators/bumpers as per the photos. I was wondering if anyone could help located a set of (4)? Mine are shot. Like most of them out there.
# printed on the bottom of these:
19877F (FRT LH)
19878F (RR RH)
etc....
Thanks in advance
Thanks in advance
Those early-02, port-installed LX racks are the odd ones, and the rubber cushions/insulators are not the same as the later 03-07 pieces. I would not order 63489-60070 by year alone; verify the rack style and the shape of the old pads first, because the early rack often will not accept that later cushion. A used OEM set from a 98-02 rack is usually the realistic route, and it is best to replace all four as a matched set rather than mix years. The markings you found are useful for matching the positions, but I would compare the mounting tabs and underside profile before buying anything.
4x4 Rides in Hagerstown, MD parts out 80s/100s and ships nationwide.
Thanks for the info. Yes, I was thinking used OEM but they are hard to come by. I did look around a fair bit before posting as to avoid gumming up the forums.
I'll continue looking and check out 4x4 Rides. Thanks again
