2001 ball joint RECALL
KIRKSVILLE, MO
I need to ammend my post, my truck did NOT fall under the recall of the ball joints or the frame warranty.
I guess no news is good news.
Still, if you have a 2001, I'd have the ball joints checked (via VIN #) - just in case they need replacing.
Kirk, clarification, your frame is covered under the frame warranty and you should have received a letter from Mr T. Now, since we do not live in the "salt belt" ours will last longer, and probably not need warrantied. The ball joint thing came out years ago, and you would have had a failure by now. My VIN wasn't under it, but I did replace my upper and lower ball joints a few months ago chasing a vibration issue.... which BTW is gone!
Here's the old thread on ttora... http://www.tacomaterritory.com/forum/showthread.php?t=10366&highlight=ball+joint+recall
FlatlandTRD -
I never recieved a letter on the frame or the ball joint issue (but I did on the fuel tank) - just ran across them here so I had them checked out.
Thanks for the links - again! After I have been on here for several yrs maybe I'll be in the 'know' a little better!
