2000 LC warning light question
Hello all,
I have owned a 2000 LC for about 4 months now. Today for the second time I had 3 warning lights come on while sitting at a stop. VSC Trac, VSC Off and ABS. This happened once before about 2 months ago and just happened again today. Soon after I started moving again all three lights went off and have not come back on. Has anyone had this happen before?
Any suggestions? My LC has just at 90k on it and I have not noticed any issues with braking or driving.
Thanks in advance for your help.
I am no eggspert but since these 3 lamps are related, I would think there may be a loose connection (or impending failure) in the ABS circuit. As things may have been bumped or unplugged during your last service, I would start by unplugging and replugging connectors on the brake master cylinder, and also check that ground and power connections are tight at the battery terminals, as they may have been removed during the service.
Was the brake fluid changed during the service? If it was then the connections were possibly removed or disturbed on the master cylinder. Make sure you can't see any loose ground wires and make sure they are in place at the master cylinder. Unplug the brake booster pump motor and replug as well. My .02
