2000 LC 100 Series Remote start wiring install information?
calgary
Hi I been searching for a while on here but could only find data on newer LC (T harness versions) and 80s write up on remote starts.
I picked up a CS3000 (compustar) from 2002 Celica at the junk yard, I been using this same model since 2001 when I installed in the Supra back then . I cut it out from the celica perserving the tie in connectors and bits from the Celica wiring hoping maybe some colors are the same
Is there a write up on this website?
I will also share my findings as well..
Sorry to bump an old thread. After trying to replace my busted ignition rod, and then busted ignition switch, now dealing with no accessory power due to things being slightly misaligned, I'm considering putting some kind of simple Compustar remote starter in my 2002 LX. Not seeing much information on remote starters in the 100-series. Do you remember any of your findings or was it pretty straightforward? Maybe I'd get lucky at a junkyard too!
