Must the engine be removed to replace the motor mounts?
To add, you can use a simple support bracket too - but a well used one with all-thread that is greased to the hilt is what it takes with the 1FZ/3FE.
I built a bracket but no pics readily here - 2" box & a couple 14" pedastals in the fender lips, a couple rings of 2.5" - 1/8" box w/ all-thread welded to it via a 2" chunk of pipe to lift the weight run nuts in the all-thread up (use a couple washers to decrease drag, heavy motor). And plenty of grease. Did I mention grease?
