I bought a set of 2" spacers about a year ago for the LC. I am finally thinking about putting them on and ran into something I should have already thought about. Will the extra 2" spacers require anything diffrentnin the way of shocks? I have an OME Medium lift and OME shocks. Any help would be great.
MC
I am talking about spring spacers, such as the metaltech variety. Again, any help would be great. I know I will have to have caster checked/corrected after raising the front another 2".
MC
With the med lift 2” of front spacer is usually too much, making the front high. What is your front and rear hub to fender measurement?
Like any suspension mod, spring spacers are a compromise, the type that you have space the bump stops down. Most longer shocks require the bump stops to be lowered, so this is a good thing, kills two birds with one stone. The other type goes in with the coil, doesn’t effect stop position, probably better for your setup?
Not knowing your setup, my guess is that your not as heavily rear loaded as the OME suspension is designed for and want to cure the stink bug? In this case my first recommendation is to replace the front springs with a pair of OME heavies. They are the same spring rate, just ~1” taller, then sell the med set, recovering some of the investment. This is the “correct” way to do it.
The second option is “in the coil pack” type spacers. IIRC Mr Gasket makes some ~1” that are cheap and Man-it-ain’t-free has some that are 30mm. These options have the best chance of being a “bolt it on and go” mod, basically the same as OME heavy setup, so your currant shocks, CC bushings, etc should be fine.
If you run the spacers that you have, you will lose 2” of front travel, will likely need more CC and may need to do something with the rear to cure the rear sag look? The "lift effect" would be about the same as switching to J springs, pretty much getting into the ~4” lift extra mods territory. So the questions become, what are your plans for the rig, how big of tires, how many mods do your want to do and how hard do you plan on wheeling it? If your plan includes going into the 4”+ range, you will probably get better results by changing the whole lift and selling yours.
