2 simple axle ?'s
I've started the tear down of my FJ40 and the front axle shaft is about the same diameter as my dana 30. i always thought the shafts were supposed to be pretty beefy. anyways, i also was curios about My gear ratio but assumed it was 4.10 like all 69 cruiser. i spun the yoke at little more than 2 turns to only one turn of the drum. now, i haven't pulled the diff yet to count teeth but logically my gear ratio isn't obviously 4.10? correct? hope i don't sound to stupid.
What was the axle on the other side doing when you turn the yoke?
The differential could have been spinning,
causing the two axles to be turning at different rates. The average of the two should
be 4.1 to 1. If the other one was sitting still, then I think you would get double the
number of turns from the one that was moving, making you think that your gear ratio
was more like 2.05 to 1 (which it cannot be, such a ring and pinion was never offered
in a cruiser). Hope this makes sense.
