2 inch lift?
Cal
Hi newbie question
Planning on a simple 2'' lift on my 2017 LC200, most probably with Old Man Emu suspension
Do I need to change the springs only, the shocks only or both?
Because I want to preserve the original ride quality as much as possible.
Also, How does a lift affect KDSS?
Any other things that I should know before doing the lift?
Thanks.
Look up anything KDSS. It will most likely go over suspension install and resetting KDSS. lots of options on suspension lifts. Surf around and you will find some good stuff . If your going OME go shocks and springs. It will change the way the LC feels. A good thing. Again lots of options so surf around and ask more questions before pulling the trigger on a "lift".
Good luck brah!
