1uz, 2uz, 3uz WIRING SERVICE FOR ENGINE SWAPS
LexusV8 Engines
Supporting Vendor
Website
www.lexusv8.com
1UZ, 2UZ and 3UZ WIRING SERVICE for ENGINE SWAPS
Our wiring services start at $550.
Immobiliser removal is offered for all the various engines.
1UZ VVt-I immobiliser removal at $90.
Easy three wires to run the motor. Ignition Start and Fuel. We also give Temperature, Rev Counter, Tacho and Charge light as a standard for your cluster.
On 1UZ you will get OBD1 flash code system built into the fuse box through a LED by bridging two terminals in the fuse box. When going 2UZ and 3UZ it will be OBD2 diagnostics that can be connected to through a smart phone or diagnostics tester for live data and diagnostics information.
2UZ and 3UZ are all $140. Flashing ECU’s is free of charge.
If any connectors need to be replaced, there is a small charge averaging $6 -$8 per connector installed, applicable.
Performance flashing is also free as we program anyway for applications to suit the customers’ requirements. Performance flashing is not something we recommend as every vehicle is different and should be done on a rolling bed accordingly. Yes the performance map improves performance, but can not be set up properly for every engine swap as ratios, tyre sizes etc are all different, so we recommend keeping reliability and staying with the stock tune. Want more power then there are other engines to choose from such as the UR series of engines.
We support our customers with technical advice fully in mechanical and electrical.
We send a video of the customers harness being test run on one of our workshops test engines.
Our average turnaround time is between one to three weeks.
We based in Florida USA.
www.lexusv8.com
Email us at sales@lexusv8.com for a quote.
Contact Tim at 305 619 5355 or Sally at 770 722 2345
