1st use of my M101
SF
I attached it to my 80 series. I have a few issue though:
1- left side running light does not turn on
2- brake lights do not work on both sides do not work
MUDRAK did all the work and I am happy with it. I'm not sure if the issue is the trailer or 80. I plan to hook it up to my 60 next weekend.
I did the wildflower TRI this weekend and even thought it was built for a lot more it worked great for a weekend get away.
Nice rig! That Magiolina looks like a cozy spot for sure.
On the marker light, check the ground. The brake light thing may be a wiring issue on either the truck or the trailer
Noticed the nose down stance of the trailer. Guessing it's on the standard hitch that mounts under the bumper on the 80 to the frame? And not sure if you've retained the original lunette? However, if so, note the casting that holds the lunette has two positions. If the lunette is in the top position now, putting it in the lower position should level things out.
I have a bumper-mounted pintle I use with ours, with the lunette in the top position on the M101.:cheers:
Is that upper Bidwell Park?
Oh yeah, trailer is cool too! Don't 80's have the 4 bolt spot for bolting on a lunette in the middle of the bumper?
(CSU Chico, '00 :) )
I have a 60series as well so I won't attach it soley to our 80 series. When attached to our 60 it's totally leveled.
Here are some pics of how I originally got it
