For Sale 1PZ Engine part out
Status
Not open for further replies.
mudandrock
Back 40 Cruisers
Supporting Vendor
Montana
Website
back40imports.com
I have a 1PZ engine here that spun a rod bearing. Everything is reusable as best I can tell, but the crank will have to be ground as the number 1 Rod journal is scored.
Cylinder Head $800 no visible cracks. I can have it magnefluxed for an extra $200
Block w/crank $800 all the cylinder walls look beautiful, pistons slid right out. (Keeping the pistons for another job.
Oil pan $150
Exhaust manifold $200
Air intake manifold $200
Heat shield $50
Camshaft $300
Harmonic balancer w/a/c pulley $100
Dip stick w guide tube $50
Glow plug Buss Bar $30
Valve cover $100
Hi, I’m interested in the Toyota 1PZ cylinder head you have listed for $800.
I have a PZJ75 Land Cruiser with a cracked cast-iron 1PZ cylinder head, OEM 11101-18030.
Is your cylinder head still available?
Before purchasing, I would like to have it Magnaflux/pressure tested to confirm that there are absolutely no cracks.
Could you also confirm that it is the correct 1PZ 5-cylinder head and send me detailed photos of the combustion side and casting/part numbers?
I am located in Sarajevo, Bosnia and Herzegovina. Could you please check whether you can ship it to Bosnia, or alternatively to Croatia/Slovenia/EU?
Thank you.
Status
